Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: IH460 clutch
mkirsch
01-26-2013 20:36:02
Does the tractor shift okay? Does the clutch slip under load?
When the tractor is in neutral, there's no way the clutch could make it rock back and forth.
Also, pushes hard compared to what?
LarryNMO
01-26-2013 20:52:35
 Re: IH460 clutch in reply to mkirsch, 01-26-2013 20:36:02
I've had other ford tractors before and i don't remember those being that hard to push down with my foot.
Janicholson
01-27-2013 08:42:12
 Re: IH460 clutch in reply to LarryNMO, 01-26-2013 20:52:35
The clutch is much harder to push than a Ford. In one of the series larger than yours there was a hydraulic assist on the pedal! The clutch is designed to not be a weak point. Shifting is to be done stopped at idle. The trans fluid is thin HYtran, and doesn't stop the rotating mass as well as thick 90 wt. I think the tire has fluid in it. They slosh. Jim
LarryNMO
01-27-2013 09:43:49
 Re: IH460 clutch in reply to Janicholson, 01-27-2013 08:42:12
I'll bleed the other tire off a little to see if there is fluid in it. Thanks Its raining and sleeting this morning. Wish I was in Florida, it's only 80 Deg.
