Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: rear axle housing gasket on a regular
Fixerupper
01-26-2013 19:31:55
LOL! I had to Google vellumoid to know what you were talking about. Vellumoid is a gasket MFGR. Thanks for the quick answer. Jim
36F30
01-26-2013 20:06:56
 Re: rear axle housing gasket on a regular in reply to Fixerupper, 01-26-2013 19:31:55
Yea, they are paper resin gaskets. Buy a sheet of gasket material and cut yourself a new one, I use aviation form-a-gasket with them.
In the 1890's, a professor of chemistry at Amherst College discovered that certain paper, when impregnated with a solution of glue and glycerin, was transformed into a crackle parchment-like material that was waterproof, oilproof and greaseproof. Because of it's parchment-like quality, the material was called "Vellumoid" (meaning "like vellum or parchment"). Since our humble beginnings, Vellumoid Incorporated has become a major producer of gaskets for automobiles, trucks, and miscellaneous sealing applications.
Fixerupper
01-26-2013 20:15:42
 Re: rear axle housing gasket on a regular in reply to 36F30, 01-26-2013 20:06:56
Will and auto parts store carry it or will I have to go online? Jim
Zachary Hoyt
01-27-2013 05:48:44
 Re: rear axle housing gasket on a regular in reply to Fixerupper, 01-26-2013 20:15:42
Our local Ace hardware has gasket paper too, as well as the auto parts stores.
Zach
36F30
01-26-2013 20:43:34
Should be able to get gasket paper sheets at any auto parts store, Farm stores carry it here too. Or just silicone it like old F20 does
SweetFeet
01-27-2013 07:18:22
 Re: rear axle housing gasket on a regular in reply to 36F30, 01-26-2013 20:43:34
36F30,
Do you mind my asking what farm store you get your gasket paper from?
Fleet Farm no longer carries it around here, and TSC carries a little roll - but it is quite small. My husband used to get much larger/wider rolls of the stuff.
Thanks.
36F30
01-27-2013 09:33:42
 Re: rear axle housing gasket on a regular in reply to SweetFeet, 01-27-2013 07:18:22
SweetFeet said: (quoted from post at 08:18:22 01/27/13) 36F30,
Thanks.
Orschlens, TSC, And Shoppers Supply all carry it here. Arnold Motors and NAPA too.
Never asked at Oreilly's but they probably have it.
I have better luck with bigger sheets from Arnold Motor Supply. None of them were big enough to make gaskets for the final drive cases on my 30 so I just made them in strips and sealed it with Aviation form-a-gasket.
Just looked up Fel Pro gasket material at O'reilly's they have sheets 36" wide and rolls up to 50 yards.
http://www.oreillyauto.com/site/c/search/Gasket+Material/N0488/C0137.oap?page=1&results=20&sortBy=1
This post was edited by 36F30 at 09:45:08 01/27/13.
SweetFeet
01-27-2013 10:39:19
 Re: rear axle housing gasket on a regular in reply to 36F30, 01-27-2013 09:33:42
36F30,
Thanks will save this info for my husband. Our TSC only had a small narrow roll and they said that is all they carry anymore. And yes, it is too narrow for some applications. Thanks again.
