TractorLinks.com
Show Parts for Model:
Re: Cost of Gear Oil - Here's What I Paid
Centex Farmall
01-26-2013 16:53:49
I've thought about cutting it with 50wt motor oil. I suspect the high content of sulpherized additives contributes to corrosion when you get inevitable condensation inside the case. Easier I guess to just use hy-tran.
Duner Wi
01-26-2013 19:04:14
 Re: Cost of Gear Oil - Here's What I Paid in reply to Centex Farmall, 01-26-2013 16:53:49
40-50 Wt should work too I guess. I see some straight weights classified as GL1 on the label.
I need GL4 for old cars trucks built before 1980.
For tractors I don't know is hy tran has any EP characteristics. Be reasonable that it does. Thanks
Centex Farmall
01-26-2013 19:47:46
 Re: Cost of Gear Oil - Here's What I Paid in reply to Duner Wi, 01-26-2013 19:04:14
The best looking gears I've seen on the old stuff I have has been in the MTA's, 400's and 450's. The Hy-tran type stuff holds water but doesn't seem to react with it. The other decent looking ones (as far as corrosion) are those that have been sitting with the OLD oil in them that is just plain old oil.
TSC used to have some oil that was labeled for the old ford tractors, 8n 9n etc. I can't remember how it was worded exactly but it sounded like a GL-2 or 3.
Duner Wi
01-27-2013 06:25:30
 Re: Cost of Gear Oil - Here's What I Paid in reply to Centex Farmall, 01-26-2013 19:47:46
Thanks for info.
