1953 SM Correct Dash Box?
Pete_5959
I am not sure as to which dash box I should be using. Should it be the type that has current meter, light switch, fuse, and run/stop pull switch or should the pull switch not be included? Serial # is F42114. Thanks.
Pete - every Super M I've ever seen has had the ignition button in the cover along with the ammeter, fuse cap and light switch.
You have the correct one. Serial numbers F-28175 and L-504802 and higher used that setup. Below the numbers were just like the later M tractors with the voltage regulator mounted to the rear fuel tank support.
