Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: in frame rebuilt c123, very hard to turn over...normal?
Janicholson
01-26-2013 08:23:02
For sure if the trans is turning and it is less than 50 degrees where the tractor is located, it will be way hard to crank with the trans lube being stirred!. Pull it is OK if you don't try to start it till the clutch is loose. Block down the clutch then (ignition off) rock the tractor hard in road gear. If no joy, with the clutch blocked down) lock the brakes or block the wheels if the brakes won't hold, and use 12 volts on the starter to break free the clutch. Jim
