TractorLinks.com
Show Parts for Model:
Re: in frame rebuilt c123, very hard to turn over...normal?
rustred
01-26-2013 06:36:28
hard to turn over??? with the starter, or by hand?
PretendFarmer
01-26-2013 07:13:50
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to rustred, 01-26-2013 06:36:28
I dont have a hand crank for it and Im trying to crank it with the 6 volt....
rustred
01-26-2013 07:41:13
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to PretendFarmer, 01-26-2013 07:13:50
you may have batt. problems, or cable problems. just pull it and go from there. if you used the same brgs then that eliminates tight brgs. i believe its electrical, not mechanical.
rustred
01-26-2013 07:48:33
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to rustred, 01-26-2013 07:41:13
ooh i see its got clutch problems too, so it could be anything from flywheel back to diff. next step, get clutch loose or removed.
Janicholson
01-26-2013 08:23:02
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to rustred, 01-26-2013 07:48:33
For sure if the trans is turning and it is less than 50 degrees where the tractor is located, it will be way hard to crank with the trans lube being stirred!. Pull it is OK if you don't try to start it till the clutch is loose. Block down the clutch then (ignition off) rock the tractor hard in road gear. If no joy, with the clutch blocked down) lock the brakes or block the wheels if the brakes won't hold, and use 12 volts on the starter to break free the clutch. Jim
