Oil Seal Part No. Cross Ref
F4RM@11
I'm trying to cross the following part numbers against National or another brand at Advance Auto:
377788R91 - Oil seal, rear axle
358812R91 - Oil seal, PTO
169948C91 - Oil seal, bull pinion
I have a $50 off coupon and another 20% with their current special that's only good online that I'd like to use for parts if possible.
Look at these and compare,Victor #s
377788R91 - Oil seal, rear axle=49618
358812R91 - Oil seal, PTO=46257
169948C91 - Oil seal, bull pinion=46179 or49451
Think I have the national numbers at the tractor shed for 2 of them, Don't recognize the bull pinion number. What tractor is it for? If no answer by morning I will look. Other two will fit a M and others, if the bull pinion seal is for a M I should have a national #.
go here:
http://www.napaonline.com/
in the upper right hand corner near the SEARCH box is a check-box that says interchange. Put the IH part number in, check the box, and submit the search. They don't cross every part, but I have found alot this way
(quoted from post at 05:41:32 01/26/13) go here:
Thanks, Tom. I've found Napa's interchange to be very good too. I found seals for the bull pinions at Advance Auto and was able to use my discount.
