Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: in frame rebuilt c123, very hard to turn over...normal?
01-26-2013 05:39:43
The pistons and rods are installed in the correct orientation. I am going to drop the pan, and take another look. The numbers on the rods, indication which cylinder they belong in, are facing the distributor side of the engine.
I reused the rod bearings. No new bearings.
01-26-2013 13:34:26
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to PretendFarmer, 01-26-2013 05:39:43
Did you check ring end gap to make sure it is in spec?? If you did not you could well have rings with no gap and if so then yep you will not spin it over and could even break a ring trying to do so
