Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: in frame rebuilt c123, very hard to turn over...normal?
[Return to Forum]
PretendFarmer
01-26-2013 05:00:12
66.87.125.199
Just got my c123 put back together. New rings on 3 honed cylinders. Replaced the piston, rings and sleeve on number 1. Its very difficult to turn over...why?
[Reply]   [No Email]
Mark Robke
01-26-2013 20:39:19
67.140.179.11
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to PretendFarmer, 01-26-2013 05:00:12
What Dave Allgire said! You may want to pull pan and recheck all your rods and mains : loosen each 1 at a time and rotate the engine BY HAND after each 1.Pull your plugs and rotate by hand also. I saw a guy spin a rod bearing that jumped out of it's seat and pull started it ruining the crank! Mark
[Reply]  [No Email]
oldiron29
01-26-2013 14:55:43
74.88.11.200
pretend, C and SC were none to have bad grounds
Move the ground cable to someting cast under battery box. I have done this on all of mine with good heavy cables it should spin fine if it is not your engine build. oldiron29
[Reply]  [No Email]
El Toro
01-26-2013 13:14:31
108.3.143.30
I would pull the sparkplugs and pour some engine oil on top of the pistons. Then bump the engine over. If you're using a 6 volt battery you should have 00 battery cables no longer than necessary. Hal
[Reply]  [No Email]
Russ from MN
01-26-2013 12:16:06
68.235.89.10
You need a hand crank, very useful for setting the valve clearance. get it so it turns over smoothly with the crank and then tow it to start it. you will burn up the starter trying to start it.
[Reply]  [No Email]
Tom Fleming
01-26-2013 07:53:28
67.20.233.75
Yup, what Rustred said.................hey, I made a rhyme! :lol:
[Reply]  [No Email]
rustred
01-26-2013 06:36:28
209.115.232.65
hard to turn over???
with the starter, or by hand?
[Reply]  [No Email]
PretendFarmer
01-26-2013 07:13:50
192.249.47.207
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to rustred, 01-26-2013 06:36:28
I dont have a hand crank for it and Im trying to crank it with the 6 volt....
[Reply]  [No Email]
rustred
01-26-2013 07:41:13
209.115.232.65
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to PretendFarmer, 01-26-2013 07:13:50
you may have batt. problems, or cable problems.
just pull it and go from there.
if you used the same brgs then that eliminates tight brgs.
i believe its electrical, not mechanical.
[Reply]  [No Email]
rustred
01-26-2013 07:48:33
209.115.232.65
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to rustred, 01-26-2013 07:41:13
ooh i see its got clutch problems too, so it could be anything from flywheel back to diff.
next step, get clutch loose or removed.
[Reply]  [No Email]
Janicholson
01-26-2013 08:23:02
74.60.94.18
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to rustred, 01-26-2013 07:48:33
For sure if the trans is turning and it is less than 50 degrees where the tractor is located, it will be way hard to crank with the trans lube being stirred!. Pull it is OK if you don't try to start it till the clutch is loose. Block down the clutch then (ignition off) rock the tractor hard in road gear. If no joy, with the clutch blocked down) lock the brakes or block the wheels if the brakes won't hold, and use 12 volts on the starter to break free the clutch. Jim
[Reply]  [No Email]
todd hamilton
01-26-2013 06:33:10
174.228.70.36
Take the plugs out and turn it over by
hand to see what you've got. If it is not
binding you might have the timing
advanced a little to far.
[Reply]  [No Email]
gene bender
01-26-2013 06:25:55
67.55.226.151
Do you have good oil on the pistons you dont want them to be dry as some smoke after starting wont hurt a thing. Sounds like you did OK
[Reply]  [No Email]
John M
01-26-2013 06:24:14
209.213.28.157
Ring gap? You say you hones the other 3, did you check it for roundness, or whatever the technical term is, I forget at the moment.
[Reply]  [No Email]
Tom Fleming
01-26-2013 05:27:40
67.20.233.75
well, a brand new rebuild will need to "wear in" a bit. You have also increased (probably) the compression with the new rings and valve job. new rebuilds are always "tight".
Now, you could have a bearing cleance issue. Did you install the pistons in the correct orientation? Are the main caps installed with the correct orientation? Did you use assembly lube or oil when you assembled?
There could be a number of things "wrong" or it could just be "new, tight".
I don't know your level of experience or background, so please don't be offended by my questions.
[Reply]  [No Email]
PretendFarmer
01-26-2013 05:39:43
192.249.47.207
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to Tom Fleming, 01-26-2013 05:27:40
The pistons and rods are installed in the correct orientation. I am going to drop the pan, and take another look. The numbers on the rods, indication which cylinder they belong in, are facing the distributor side of the engine.
I reused the rod bearings. No new bearings.
[Reply]  [No Email]
old
01-26-2013 13:34:26
209.86.226.19
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to PretendFarmer, 01-26-2013 05:39:43
Did you check ring end gap to make sure it is in spec?? If you did not you could well have rings with no gap and if so then yep you will not spin it over and could even break a ring trying to do so
[Reply]  [No Email]
Dave Allgire
01-26-2013 05:25:19
96.35.208.3
You don't say whether you installed new rod/main bearings. If you did, are they the correct size? Did you overtorque the rods that you had out? Just a couple of things to check. An easy way to check is to turn the engine over by hand after torquing the rod you just torqued before moving on to the next one.
[Reply]  [No Email]
rustred
01-27-2013 06:38:39
209.115.232.65
 Re: in frame rebuilt c123, very hard to turn over...normal? in reply to Dave Allgire, 01-26-2013 05:25:19
he said he used the same old brgs. just as long as they are not missmatched from original locations, and in good shape it will be fine.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
