TractorLinks.com
Show Parts for Model:
Re: Super C Governor Problem
Bud W
01-25-2013 16:47:48
No you can't move the carb linkage with the engine running.
Janicholson
01-25-2013 16:59:47
 Re: Super C Governor Problem in reply to Bud W, 01-25-2013 16:47:48
Something (like worn thrust bushing, or the main governor bushing in the distributor drive end), is jamming the output to the rock shaft (output shaft to the left side of the engine) can you wiggle the gear shaft up and down easily? Jim
Bud W
01-25-2013 17:22:23
 Re: Super C Governor Problem in reply to Janicholson, 01-25-2013 16:59:47
Yes it wiggles up and down. When I pulled the gear out and reached in the distribtor drive will move a little but not much. Any ideas on how to get the shaft bumber and spring out? By the way thanks a bunch for all the help.
Janicholson
01-25-2013 17:38:28
 Re: Super C Governor Problem in reply to Bud W, 01-25-2013 17:22:23
If the shaft end wiggles up and down more than 1/16" I would replace the main bearing. The Bumper spring assembly might be easiest to remove when it is out of the tractor. Then (as far as I can see, it will require some solvent, and careful manipulation to get it free. jim
Bud W
01-25-2013 17:58:52
 Re: Super C Governor Problem in reply to Janicholson, 01-25-2013 17:38:28
Do you have a part number for the main bearing? I don't see it in my parts book. Funny thing is this problem happened after the tractor had set for a month or two. Everything was fine when I shut it down. Its kind of like a catastrophe failure versus a worn bearing. Would it make sense that the fact that the shaft bumper will not extend could allow the pinion and everying thing attached to slide forword causing my problem???
Janicholson
01-26-2013 07:39:35
 Re: Super C Governor Problem in reply to Bud W, 01-25-2013 17:58:52
It could, (I wish I was there) That bearing might be in the front cover illustration. It is troublesome in many high hour tractors and replaced, I do believe it is available.
I would sure get the bumper operational first, to see if that is the issue. Jim
Bud W
01-27-2013 17:50:10
 Re: Super C Governor Problem in reply to Janicholson, 01-26-2013 07:39:35
Jim
I finally got the bumper working and it appears to have solved the problem. Thanks a bunch for sticking with me.
Bud
Janicholson
01-27-2013 20:41:01
 Re: Super C Governor Problem in reply to Bud W, 01-27-2013 17:50:10
Thanks it was an unusual issue. Glad it worked well!! Jim
