Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: alternator diode question
01-25-2013 08:24:28
The only thing needed to get rid of the risistor is a 12 volt coil. The points and condenser will be just fine. Dizzy stays the same. Only reason I kept the 6 volt coil on my M is I had the resistor and was low on funds at the time. Going with a 12 volt coil next tuneup.
01-25-2013 14:27:49
 Re: alternator diode question in reply to oldtanker, 01-25-2013 08:24:28
The voltage dropping resistor is a lot cheaper than the 12 volt coil,but I also thought that the condenser in the dizzy would need changed.
01-25-2013 19:37:33
 Re: alternator diode question in reply to merlynr, 01-25-2013 14:27:49
It is cheaper but I'm a student of the "keep it simple" school. Taking the resistor out just eleminates one more thing that could go wrong. 12 volt coil really isn't that expensive. Last one I got was around 25 bucks.
01-25-2013 17:05:00
Not needed, they are rated in the area of 400 volts, so 6 or 12 is not a problem. Jim
