Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: alternator diode question
Moondoggie
01-25-2013 07:56:29
Ah! So that"s why my 340 runs on after shutoff, for a few seconds. I"ve wired the diode in series, but not the resistor. Anyone care to draw a short wiring diagram? Learn something new each day. Thanks!
Janicholson
01-25-2013 15:30:06
 Re: alternator diode question in reply to Moondoggie, 01-25-2013 07:56:29
This should help. The Starter is from a large frame but your relay should be similar. Both should not be necessary if the diode is placed with the band end as shown. Jim
merlynr
01-25-2013 08:12:41
Google " bob melville" for drawings.
I converted my H and used a Chrysler voltage dropping resistor to keep the 6v coil and dizzy the same. Just reverse the leads on the coil because It's now 12v neg gnd.
oldtanker
01-25-2013 08:24:28
 Re: alternator diode question in reply to merlynr, 01-25-2013 08:12:41
The only thing needed to get rid of the risistor is a 12 volt coil. The points and condenser will be just fine. Dizzy stays the same. Only reason I kept the 6 volt coil on my M is I had the resistor and was low on funds at the time. Going with a 12 volt coil next tuneup.
Rick
merlynr
01-25-2013 14:27:49
 Re: alternator diode question in reply to oldtanker, 01-25-2013 08:24:28
The voltage dropping resistor is a lot cheaper than the 12 volt coil,but I also thought that the condenser in the dizzy would need changed.
oldtanker
01-25-2013 19:37:33
 Re: alternator diode question in reply to merlynr, 01-25-2013 14:27:49
It is cheaper but I'm a student of the "keep it simple" school. Taking the resistor out just eleminates one more thing that could go wrong. 12 volt coil really isn't that expensive. Last one I got was around 25 bucks.
Rick
Janicholson
01-25-2013 17:05:00
Not needed, they are rated in the area of 400 volts, so 6 or 12 is not a problem. Jim
