Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall Super A Camshaft removal
Machine249
01-23-2013 19:01:31
As stated before, remove lifters and oil pump, then try to pull out from the gear end. If you try to pry on the gear you will break the gear and/or camshaft (ask me how I know). If push comes to shove, on the back side of the cam is a plug, like a freeze plug, it can be removed and the cam can be tapped out from the rear. I had a C113, that had sat for a loooong time and everything was seized. Be patient and good luck with it.
gene bender
01-24-2013 02:43:17
 Re: Farmall Super A Camshaft removal in reply to Machine249, 01-23-2013 19:01:31
You cant get the lifters out until the cam is removed. But you do need to remove the oil pump.
adamih
01-23-2013 19:42:20
Thanks guys, and this motor has also been sitting for a long time so everything is pretty sticky i have everything gutted from the block except the camshaft so i think ill try the suggestion of removing the plug from the other end and tapping it out, Thanks for the help!
Jim Becker
01-23-2013 19:37:40
As stated before, the lifters come out after the camshaft.
