Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: a/c on '86 series
01-23-2013 17:39:20
Reading your post I have a question, when you say that your 1086 looses it's refrigerant charge rather quickly, are you talking hours, days, weeks, or months?
Dave from MN
01-23-2013 18:23:10
 Re: a/c on '86 series in reply to charlieu, 01-23-2013 17:39:20
Well, within 5 days of it getting 2 cans of ref, it no longer had enough to operate and the ref light came on in the ca, and it would not cool at all
01-23-2013 19:21:04
 Re: a/c on '86 series in reply to Dave from MN, 01-23-2013 18:23:10
If your system is going flat in 5 days you have a bad leak. I'm sure that I'm going to have people throwing rocks at me, but what I do, when I'm looking for a bad leak is to pressurize the system with compressed air. I hook a fitting up to my shop air hose and open it up to pressureize the entire system to 140 lbs. I then get a spray bottle full of soapy water and start spraying down the system, all the fittings, hoses, connections, condenser, and everything you can gain access to. You are watching for air bubbles. Once you find and fix the leak you need to pull a vacuum, and make sure that your system holds that vacuum for 30 minutes. I then would replace the receiver dryer, pull full vacuum again, before recharging. The point is you need to find where it's leaking, so you know what needs to be replaced. Good luck
