Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall Super A Camshaft removal
Janicholson
01-23-2013 16:42:49
Remove all lifters, Remove the oil pump. Remove the front cover. remove the retainer plate behind the gear. Support the shaft as it is withdrawn from the block towards the front. Jim
teddy52food
01-23-2013 18:06:33
 Re: Farmall Super A Camshaft removal in reply to Janicholson, 01-23-2013 16:42:49
Lifters come out after the cam.
Jim Becker
01-23-2013 17:57:18
That won't happen. Take off the rocker arms, turn the block bottom side up and push the lifters away from the camshaft. . . .
Janicholson
01-23-2013 18:30:33
 Re: Farmall Super A Camshaft removal in reply to Jim Becker, 01-23-2013 17:57:18
Ah yes. correct you are. To avoid having it upside down, magnets could be put on the sides of the lifters to hold them up, Or possibly O rings tight enough. Jim
gene bender
01-24-2013 02:41:50
 Re: Farmall Super A Camshaft removal in reply to Janicholson, 01-23-2013 18:30:33
You cant get any o-rings on the lifters. Usually the lifters if pushed all the way up will stay as the bottom bart of the body doesent lift that high so its got some varnish and the lifters will stay .
