International 100 how can this be?
Anonymous-0
My tractor has what appears to be the original serial number tag. It is stamped 559 J and that is about all I can read. According to the serial number lists I have looked at this should be a 1955 model. All the casting dates range from April to September with a suffix letter B. This includes engine, trans, differential etc. B reportedly designates 1956. How can this be?
Thanks,
DeWayne
Thanks but I am referring to the serial number which tells us the tractor is a 1955 model but the date code B on the castings means they were not produced till 1956. Something is not consistent with this information.
559 is a 1954 model. See if you can find a casting code on the clutch housing, The letter should be A for 54, meaning the casting was replaced. The serial tag could also have been replaced. The tag could also be a 55 if you can find another number after the 9. To be a 56 it has to have 1 as the first number and another number following the 9. If the 559 is very clear, then you have a different casting.
Casting codes can't lie. If the casting code on the housing that the tag is on is a b then the tag has been replaced.
According to this sites serial number list which I believe to be correct makes your tractor a 54, so apparently the bell housing has been replaced at one time since B is the correct casting letter for 1956.
Most likely you have misidentified a 130 as a 100. 130 number 559 was built in November 1956. You casting dates all agree with that build date.
We need more information. Read the block casting number under the front spark plug and report back to us. I suspect you have a Farmall 130.
(quoted from post at 18:51:42 01/23/13) 559 is a 1954 model. See if you can find a casting code on the clutch housing, The letter should be A for 54, meaning the casting was replaced. The serial tag could also have been replaced. The tag could also be a 55 if you can find another number after the 9. To be a 56 it has to have 1 as the first number and another number following the 9. If the 559 is very clear, then you have a different casting.
I thought '54 is Z and '55 was A.
(quoted from post at 19:29:19 01/23/13) Most likely you have misidentified a 130 as a 100. 130 number 559 was built in November 1956. You casting dates all agree with that build date.
Sounds most logical right now since it is covered in Bs.
Thanks guys. I was starting to suspect the 130 notion myself but the fella I bought it from says that he grew up near this tractor and used it numerous times before he bought it and he is convinced it is an International 100. The clutch housing definitely has the B suffix meaning it is a 1956 part. The serial tag does not appear to have been tampered with. I can not legitimately read the engine code date with the hydraulic lines in the way but all other casting dates are suffix B. Is there any other method or change of parts that might give a clue to whether this is really a 100 or 130.
Look for the engine number, the stamped in sequential number, not a cast in number. It should be on a machined boss at the top edge of the engine block, more or less below #1 spark plug. The governor control rod should be the only obstruction to seeing it.
I typed in the wrong letter for the year, A is 55. I have three 53 Farmalls with casting codes of Y, so 54 is Z, I should have known when I read my response before posting.
