Keith R E
New User
Is there anything available that would tell me what parts from other IH and Farmall tractors would interchange with my 504
Thanks
Your local dealer should be able to tell you. There's not alot of parts that interchange with the 504. Alot of gas engine parts will interchange with smaller engines of the same family (C153, c135, c123, c113). But the engine block is unique, not even the c153 from a combine has the same bolt pattern. What are you looking for in particular? maybe I can help you out. I restored a f-504 about three years ago. Let me know if I can help.
Your dealer can tell you if a specific part will fit. You give them the part number, and they look it up.
I can't imagine the system is programmed to work the other way. Besides the list you'd get would be ridiculously long and completely useless.
