What parts do I need to do this?
IHMANKY
Use to rake hay with a Super C on a side delivery rake, but moved into a V rake couple years ago and smallest tractor other than the super C and an H I have is 95 HP and it's a heavy dude. I have used it past couple years but really would like to use one of those tricycles to rake with again. What do I use to make the single hydraulic line I have operate this two-way cylinder for fold in/out? Do I add a two-way valve on the hydraulic outlet and plumb the return back to the reservoir? I have no idea what I need to pull this off.
You will need hoses, a bracket for couplers on the rear of the H platform, Male and Female couplers, (or those that match the hoses on the rake as is). and a open center two way control valve. Make sure they are break away couplers, and the mount is solid to the tractor. Mount the control on the light bar, or other easy access location for convenience. It is pretty easy. Use Hytran or what is in the big tractor now, don't mix the fluids ! Jim
It's acctually pretty easy.On the H,Get a spool valve.Mount it someplace handy.Take the 'pressure' hose and hook it to the inlet of the valve.Take another hose and go from the return side of the valve down to the belly pump 'drain.Then run two hoses from the valve to the implement."Presto",you're set!Someone else will come on to "fill in the 'holes' ".Pictured is a Super M with a similar setup.
