TractorLinks.com
Show Parts for Model:
Re: FARMALL 460 Stalling Issue
teddy52food
01-21-2013 18:51:45
Was there a venturi in the carb & did you get it back in?
RJG
01-21-2013 20:46:35
 Re: FARMALL 460 Stalling Issue in reply to teddy52food, 01-21-2013 18:51:45
There is a venturi and yes it was cleaned and put back in............
pete 23
01-21-2013 20:01:07
Speaking of venturi's, last year, friend of mine called me over as he had the carb off a half dozen time and called me a few times. Tractor ran like a dream at idle, needed almost full choke to run wound up. I pulled carb and he had the venturi in upside down. Not many carbs you can do that on, I believe it is the marvel schebler. Can't put it in wrong on a 460 but could leave it out. Main nozzle can be left out also or damaged.
RJG
01-21-2013 21:06:48
 Re: FARMALL 460 Stalling Issue in reply to pete 23, 01-21-2013 20:01:07
The venturi on this one only goes in one way, and I sure would have noticed if I'd left that big sucker out. The main nozzle looks pretty good on it.
I'm a pretty fussy guy when it comes to taking thinks apart and reassembling. I keep a real clean work area so I can see what came out and what has to go back in. I'd sure be upset if I finished working on a carburetor and had parts left over.
