| Farmall & IHC Tractors Discussion Forum |
Topic: Re: FARMALL 460 Stalling Issue
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| RJG
01-21-2013 18:10:46
74.46.209.110
You're talking to a relative "newbie" here. How is the main jet set on the H and the M? I've set this one to 5 full turns out.
Thanks..
Bob |
[Reply] [No Email] | |
| Curt Cooke
01-22-2013 08:11:40
64.186.50.66
Re: FARMALL 460 Stalling Issue in reply to RJG, 01-21-2013 18:10:46
| Don't ignore the simple. Quality premium fuel. |
| CNKS
01-21-2013 18:36:23
216.144.104.128
| In until rough, out until smooth plus a quarter or half turn if needed under load. The carb was changed to 5 turns out with the Super H and Super M. It can be turned in for lighter loads, probably no less than 3.5-4 turns out. |
| ss409
01-22-2013 10:47:13
72.53.194.237
Re: FARMALL 460 Stalling Issue in reply to CNKS, 01-21-2013 18:36:23
| ive soaked carbs in good cleaners, that tiny brass stem in the carb bowl had a bunch of debris at the bottom of the passage. had to use a drill bit n lightly run it thru there with that small stem removed. pulled out alot of debris n really helped my old 460. |
| RJG
01-22-2013 11:02:47
74.46.209.110
Re: FARMALL 460 Stalling Issue in reply to ss409, 01-22-2013 10:47:13
Are you referring to the small stem that the main adjusting screw at the bottom of the carb. pokes into? If so...it sits all the way at the bottom of the carb well and looks like it would be pretty tough to get out. How did you remove it? Is it pressed in there? Screwed in?
Thanks.
Bob |
| ss409
01-23-2013 06:01:59
72.53.194.237
Re: FARMALL 460 Stalling Issue in reply to RJG, 01-22-2013 11:02:47
| should have the IH carb on it. i think the main jet size is around .055. pop that bowl off n go to the harware n find numbered drill bits. find the bit that fits the main jet as the starting point, then go up 3 sizes bigger. I would say that a .080 main jet would help the stumble n power loss if nothing else is wrong. my old 460 with a 263, the carb jetting was .090 on the main jet size, but i had her running 2300rpm. ran great! another way would be to find a 715 combine carburator that has extra ports to deliver fuel better. |
| RJG
01-23-2013 07:21:10
74.46.209.110
Re: FARMALL 460 Stalling Issue in reply to ss409, 01-23-2013 06:01:59
Thanks for the suggestion ss409. Not sure I want to go there yet. I need to eliminate all other possibilities before starting to modify things. When/if I ever get this sorted out...I'll let you guys know what I found.
Bob |
| ss409
01-22-2013 13:44:14
72.53.194.237
| no, thats the main jet. this stem sits in the bowl gasket surface of the carb bowl,sits right in front of the venturi hole,, sticks up,, n remove it with a small std screwdriver. this is a deep internal port that can have alot of crud hidden thatll cause some problems in tuning. find ya a numbered drill bit that fits in, once that stem is removed n see if theres any debris inside. a side note, plug gap, and indexing the plugs helps run better in cold weather. ive taken spark plugs out then hooked up to the coil wire n then looked at the spark at the plug. adjust gap till you get a good hot spark. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
