TractorLinks.com
Show Parts for Model:
Re: FARMALL 460 Stalling Issue
Janicholson
01-21-2013 17:45:59
With it disassembled, soak it for at least 24 hours. Move it around in the soak at least 3 times. Then use fine wire to poke through with some spray to help juice it up. Then blow it out.
Make sure the holes in the stem of the main jet are very clean. The load jet (five turn needle) can be adjusted more than 5 turns, but should not need it.
I do not have a float height # for that unit. Jim
The tractor vet
01-21-2013 19:03:05
 Re: FARMALL 460 Stalling Issue in reply to Janicholson, 01-21-2013 17:45:59
1 5/16ths' Just finished up one . And it took three weeks to get the green slime out of it . Been seeing more of this GREEN SLIME in the past two years and it does not want to come out . Even with my KICK AH POO joy juice it is hard to KILL as that is the only words i can use as it has a tendency to come back .
RJG
01-21-2013 21:00:57
 Re: FARMALL 460 Stalling Issue in reply to The tractor vet, 01-21-2013 19:03:05
Is 1 5/16 the float setting? That would be the distance from the bottom of the float to the carburetor surface above it, correct??
Thanks.
Bob
RJG
01-21-2013 17:48:24
Thanks Jim.....
Bob
