Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: FARMALL 460 Stalling Issue
01-21-2013 17:37:36
Carb is likely fine as is. The problem is the heat riser (flap) in the manifold. If the spiral spring on outside of manifold is missing or broke, replace it and the 460 will be fixed, good for another 55 years.
01-21-2013 17:46:22
 Re: FARMALL 460 Stalling Issue in reply to wolfman, 01-21-2013 17:37:36
Thanks for the info., but I did check the heat riser flap and spring. They're both present and seem to be working well. The weight starts out vertical when the manifold is cold, and slowly moves to horizontal as the manifold heats up. It moves very easily and the spring always returns the weight to the vertical position when the engine is off and cold.
