Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: FARMALL 460 Stalling Issue
[Show Entire Topic]  [Return to Forum]
Janicholson
01-21-2013 17:23:20
74.60.94.18
Lean at the carb. Getting the passages clean is difficult. Don't take it as a flame, it just will take another cleaning. The high speed circuit is just not clean. Float level (if 1/8" low) is also a lean causing issue, but idle circuits will also act up. Jim
[Reply]   [No Email]
RJG
01-21-2013 17:34:23
74.46.209.110
 Re: FARMALL 460 Stalling Issue in reply to Janicholson, 01-21-2013 17:23:20
Hi Jim;
I hear you, but what do I need to do to get the high speed circuit clean? This will be the third time I've had it off and "cleaned" it. Some of the passage ways are completely untouchable. I used wire to feel and poke my way in and out of them. And then used high pressure air to blow into the various passage ways. What are the float specs for that carb? My rebuild kit didn't specify and I basically just set the float to be parallel with the upper carb. body.
Thanks.
Bob
[Reply]  [No Email]
Janicholson
01-21-2013 17:45:59
74.60.94.18
 Re: FARMALL 460 Stalling Issue in reply to RJG, 01-21-2013 17:34:23
With it disassembled, soak it for at least 24 hours. Move it around in the soak at least 3 times. Then use fine wire to poke through with some spray to help juice it up. Then blow it out.
Make sure the holes in the stem of the main jet are very clean. The load jet (five turn needle) can be adjusted more than 5 turns, but should not need it.
I do not have a float height # for that unit. Jim
[Reply]  [No Email]
The tractor vet
01-21-2013 19:03:05
75.19.126.114
 Re: FARMALL 460 Stalling Issue in reply to Janicholson, 01-21-2013 17:45:59
1 5/16ths' Just finished up one . And it took three weeks to get the green slime out of it . Been seeing more of this GREEN SLIME in the past two years and it does not want to come out . Even with my KICK AH POO joy juice it is hard to KILL as that is the only words i can use as it has a tendency to come back .
[Reply]  [No Email]
RJG
01-21-2013 21:00:57
74.46.209.110
 Re: FARMALL 460 Stalling Issue in reply to The tractor vet, 01-21-2013 19:03:05
Is 1 5/16 the float setting? That would be the distance from the bottom of the float to the carburetor surface above it, correct??
Thanks.
Bob
[Reply]  [No Email]
RJG
01-21-2013 17:48:24
74.46.209.110
Thanks Jim.....
Bob
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
