53 farmall cub needle valve
Anonymous-0
i am tring to help on a 53 farmall cub he is needing a needle valve but didnt see any numbers on the carb it has a triangle shaped needle valve but leaks gas thanks in advance
jerry
If your talking the float needle valve that is a part that comes with any good carb kit. The needle and the seat and gaskets all come in a good carb kit
The carburetor on a Cub is the "IH 3/4-inch updraft." It should have an IH logo on the side of the bowl.
Do NOT use a carburetor kit from Tractor Supply. It comes with the wrong needle.
