| Farmall & IHC Tractors Discussion Forum |
Topic: IH 460 hydra-touch issue
[Return to Forum]
| Author |
[Modern View]
| Noah in IA
01-21-2013 10:40:44
24.149.10.69
Hey all,This weekedend I attached a Westendorf WL30 loader to my dad's IH 460. I used the right hand side remote hydraulic ports for the bucket tilt cylinders and the left hand side remotes for the main lift cylinders. The valve which operates the tilt cylinders works fine but the valve handle which WOULD actuate the main lift cylinders (left hand side remotes) is stuck. My gut tells me the linkage itself is not the problem but more likely the spool is stuck within the valve body. I plan to purchase a service manual for the 460 hydra-touch but any hints you might be able to offer to steer me in the right direction would be much appreciated. Also, it appears to me that neither of the remote hydraulic sets had ever been used as I had to remove some ancient, brittle plastic plugs from them and then spend several hours working to get the release collar to move back and forth freely. Thanks in advance, Noah |
| Mark (ECIN)
01-21-2013 18:50:32
38.123.15.238
Re: IH 460 hydra-touch issue in reply to Noah in IA, 01-21-2013 10:40:44
| Try messing with the little valve down by your feet on the dash. Two little knobs (one for each outlet) you can put an adjustable wrench on to turn |
| Janicholson
01-21-2013 19:09:43
74.60.94.18
Re: IH 460 hydra-touch issue in reply to Mark (ECIN), 01-21-2013 18:50:32
| Ok to turn it within the limits of the roll pin. be sure to leave it the way it was. Jim |
| Janicholson
01-21-2013 12:29:49
74.60.94.18
| Getting to the valves in the cold is tough. If inside. (-8 degrees here today) take the sheetmetal off to gain access. look to be sure the linkage is actually free (moves a little) if so remove it and put some ATF on the valve spool where it is visible. tapping on the spool with a plastic hammer while turning on the flat, where the hole is, with a small wrench can free them up. No whacking, and no major twisting. Jim |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
