TractorLinks.com
Show Parts for Model:
Farmall 450
Bud Kaiser
01-20-2013 20:18:59
Does anyone know of a place to get rod bushings for my 450. I could only find them at Case IH but 76$ a piece seems high.
Chester5731
01-22-2013 09:07:58
 Re: Farmall 450 in reply to Bud Kaiser, 01-20-2013 20:18:59
Last night I found the ones I have. They are tisco # 45748-dar and they have clevite 01251 stamped in them. I don't know if they would fit a 450 or not.
D Slater
01-22-2013 10:58:12
 Re: Farmall 450 in reply to Chester5731, 01-22-2013 09:07:58
Chester those are for a M, SM, SMTA and up to a serial number break on 400 engines. They are for a bigger rod end opening and a bigger piston pin than a 450. Some places have those for just under $10.00 and one place $5.00.
Huskers86
01-21-2013 19:10:07
I'll even give the part number 364913 and are $4.99 each.
D Slater
01-21-2013 20:59:43
 Re: Farmall 450 in reply to Huskers86, 01-21-2013 19:10:07
364913 won't work, to small. 450 uses # 364921R1. I couldn't find 364921R1 on that site.
Huskers86
01-22-2013 06:54:10
 Re: Farmall 450 in reply to D Slater, 01-21-2013 20:59:43
Quoting Removed, click Modern View to see It states the 364913 is for the c281 and others, this is agkits part number. Is the 364921R1 a farmall number?
D Slater
01-22-2013 07:12:45
 Re: Farmall 450 in reply to Huskers86, 01-22-2013 06:54:10
364913 is a IH number also, agkits just left the R1 off. That bushing is for 6 cylinder engines like used in some 460, 560 and others. Not sure, but think agkits should have put 282 in the listing instead of 281.
Huskers86
01-22-2013 07:46:54
 Re: Farmall 450 in reply to D Slater, 01-22-2013 07:12:45
Quoting Removed, click Modern View to see I see, I have a 450 gas that I'll be overhauling some day so I'm trying to figure this out so I can get the right ones when I order parts. On my 460 I had to hone out a little bit on the rods to get the proper fit. I think this is pretty common but I have not done a lot of them.
Huskers86
01-21-2013 19:01:26
I'll speak up so you can hear me. AGKITS.COM $5 to $10 each. I've ordered stuff there and have had no complaints.
Greg Lussetto
01-21-2013 07:14:07
Vollbrachts in Columbus, NE has them much cheaper. 402-564-5993
Greg
Chester5731
01-21-2013 06:29:57
I did have a set laying around for my super M but I don't know what diameter they are. They were from tisco about 20 years ago. I can check and see what they are and let you know.
D Slater
01-21-2013 05:30:44
Can't believe they are that high now. After checking I see them from $58.?? to a $160 plus each. Can still get the bushings for the C-264 engines before they changed the C-264 to the same rods as a C-281 for $10 to $15 or a little less. Also you can get the adapter bushings to put in previous rods to use the C-281 piston pin size in older rods for a little less than than the 450 bushing. And I thought they had got way to high. Both those bushings are bigger than a 364921r1 bushing. Think someone in the supply chain is taking us to the cleaners. YT has reconditioned small pin C264 and 281 connecting rods listed for $146.?? and just the bushing for $112.??.
d beatty
01-20-2013 20:59:28
Try Bates Corporation Boubon, IN. Theirs start out at $17.00 up to $100.00 depending on what size you need.
Huskers86
01-20-2013 20:50:16
Quoting Removed, click Modern View to see I don't know if this site sell them or not but try agkits.com...they have them from $5 to $10.
Bud Kaiser
01-20-2013 21:51:52
 Re: Farmall 450 in reply to Huskers86, 01-20-2013 20:50:16
Bates wants 96$ a bushing.This seems un reasonable anybody else have any ideas. Machine shop said they could make some out of brass.These would not be like stock, they have metal where they contact the rods, They said this should be okay.What do yall think? I may have to for 20$ a piece, cannot see paying as much for the bushing as I did for the overhaul kit.
Janicholson
01-21-2013 13:06:19
 Re: Farmall 450 in reply to Bud Kaiser, 01-20-2013 21:51:52
Brass is a common pin bushing material. The clearance is way tight, so a pin fitting machine using a hone is best practice. most are fit to .0005 to .0008" looser and it will make noise. Jim
