Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Janicholson IH460 wiring
01-20-2013 19:16:07
The wire from the stud on the back of the ALT. (red 10ga.)goes directly to the amp meter. The amp meter is a shunt device. (it has a heavy conductor inside with a known very small resistance. This resistance has the meter connected across the terminals. Thus it passed plenty of amps) The 10ga. wire then goes to the starter motor solenoid, where it connects to the battery cable from the + battery post. From there it goes to the battery, charging it. The - battery cable is grounded, as is the alternator, thus completing the charging circuit. Jim
01-22-2013 09:03:35
 Re: Janicholson IH460 wiring in reply to Janicholson, 01-20-2013 19:16:07
I just noticed this post. Very clear! One Question. Does the wire from the Alt Stud connect to the + or _ on the meter?
01-22-2013 13:35:44
 Re: Janicholson IH460 wiring in reply to Moondoggie, 01-22-2013 09:03:35
There is no standard in the industy as to which is which. I have seen them marked with the - terminal grounded when it has positive ground. It is usually an experiment with a new meter, but a flip if the polarity is changed and the meter was working correctly. Using a headlight and a couple of jumpers and a battery will be easy enough to assure it is connected so it charges going to the right. Jim
