Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Puzzling problem - IH 284 -- intermitant stuck transmiss
Janicholson
01-20-2013 08:57:51
The brakes are hydraulic (as shown in the caseih.com on line parts description) As such they should move at the pedal about an inch before doing any braking. If one pedal is rigid, and does not move, it could be that the brake cylinder is mis adjusted and not allowing the pressure to be released. The piston in the master cylinder for that brake must retract all the way to the limit of the bore. if it doesn"t. or if the cup is swelled up covering the compensating port, the brake will stay on. If both wheels are in the air, and the engine is off and the trans is in any gear, one tire should spin forward moving the other backward (differential) easily. If not, there is an issue with either brakes (I hope because it is easy) or a bearing, Jim
escottpeterson
02-02-2013 12:43:43
 Re: Puzzling problem - IH 284 -- intermitant stuck transmiss in reply to Janicholson, 01-20-2013 08:57:51
Was out of town so couldn't work on the tractor for a while. Weather hasn't warmed up (-25 this morning) but today I jacked up the back end and the back wheels turn pretty easily, except at one point they get significantly tougher to turn. The resistance lasts about 1/4 or less of a turn, then gets easier again. No noticeable difference between tires turning.
The seals on the brake cylinders are intact, although as I said earlier when I disengage the bar that connects the two brake pedals the left pedal has play and the right one doesn't move at all.
Does this help at all with the diagnosis?
If the brake cylinder was frozen would the wheels turn? Thanks. Erik
Escottpeterson
01-20-2013 12:36:05
Thanks Jim. Out of town for a few days but will try when I get back with what I find. Thanks for your help. Erik
Copyright © 1997-2015 Yesterday's Tractor Co.
