Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Puzzling problem - IH 284 -- intermitant stuck transmiss
[Show Entire Topic]  [Return to Forum]
escottpeterson
01-20-2013 08:23:23
67.7.198.128
mkirsch and janicholson. A bit of an update, and thanks for hanging in there with me.
I put it in neutral this morning and tried to push, but alas at 165 pounds I am little match for a ton tractor to make a real test of it in the shed. So I started it up and backed it up a bit (no problems at all) and then let it roll forward in neutral about 5 feet. That worked.
I jacked the back end up and when in neutral I couldn"t turn either wheel. Not sure if I was doing something wrong or not, but it also seems like a lot of gears to turn by hand so can"t answer whether on wheel turns harder than another ????
But here is something new I discovered as I looked at the brake mechanism. First off, the seals all look good around the linkages. But when I push the brake down there is no give (and when moving forward little braking action)-- push pedal ... no movement of anything to actually "brake". But when I decouple the brake pedal (there is a bar that connects the right and left pedals so they go down together) the left pedal - presumably for the left rear wheel brake appears to work normally (push the pedal and it moves -- tho what "normal" means is a guess since I have never looked at it before) while the right pedal - presumably for the right rear wheel won"t budge. It makes me think that if a brake is stuck it might be that one. Make sense?
Now -- how does one "unstick" a brake? And why if the brake is stuck on can I back up or move in a normal manner at all?
Thanks for your brains on this one.
[Reply]   [No Email]
Janicholson
01-20-2013 08:57:51
74.60.94.18
Re: Puzzling problem - IH 284 -- intermitant stuck transmiss in reply to escottpeterson, 01-20-2013 08:23:23
The brakes are hydraulic (as shown in the caseih.com on line parts description) As such they should move at the pedal about an inch before doing any braking. If one pedal is rigid, and does not move, it could be that the brake cylinder is mis adjusted and not allowing the pressure to be released. The piston in the master cylinder for that brake must retract all the way to the limit of the bore. if it doesn"t. or if the cup is swelled up covering the compensating port, the brake will stay on. If both wheels are in the air, and the engine is off and the trans is in any gear, one tire should spin forward moving the other backward (differential) easily. If not, there is an issue with either brakes (I hope because it is easy) or a bearing, Jim
  [Reply]  [No Email]
escottpeterson
02-02-2013 12:43:43
67.7.211.219
Re: Puzzling problem - IH 284 -- intermitant stuck transmiss in reply to Janicholson, 01-20-2013 08:57:51
Was out of town so couldn't work on the tractor for a while. Weather hasn't warmed up (-25 this morning) but today I jacked up the back end and the back wheels turn pretty easily, except at one point they get significantly tougher to turn. The resistance lasts about 1/4 or less of a turn, then gets easier again. No noticeable difference between tires turning.
The seals on the brake cylinders are intact, although as I said earlier when I disengage the bar that connects the two brake pedals the left pedal has play and the right one doesn't move at all.
Does this help at all with the diagnosis?
If the brake cylinder was frozen would the wheels turn? Thanks.
Erik
  [Reply]  [No Email]
Escottpeterson
01-20-2013 12:36:05
198.228.228.175
Thanks Jim. Out of town for a few days but will try when I get back with what I find. Thanks for your help. Erik
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
