| Farmall & IHC Tractors Discussion Forum |
Topic: Puzzling problem - IH 284 -- intermitant stuck transmissi...
[Return to Forum]
| Author |
[Modern View]
| escottpeterson
01-19-2013 17:02:09
67.7.220.134
I"m a newbie to the forum here with a question about my 1978 IH 284 gas tractor. Earlier this winter I couldn"t get it started, but today I got it started after finding a bad wire between the coil and points. This meant the tractor sat in a cold shed (northern Minnesota) for a few months. But when I started it today and tried to back up it was like the wheels were locked -- it wouldn"t move. I tried going forward and the same thing. Eventually it budged backwards, but sounded like something was really, really tight. For what it is worth it was about 28 degrees when I started it. I thought maybe there was water in the hy-trans fluid so drained it. The 284 takes about 3.4 gallons and I got pretty near that out. The fluid wasn"t that lovely color of new fluid, but it wasn"t milky or sludgy either. I didn"t see any real noticeable water. I filled it back with new fluid (happened to come straight from the store so warm - if that means anything) and presto: worked like a charm. Backed right up, and feeling proud I went out and started plowing the quarter mile drive with the grader attachment. Got most of the drive done (about 15-20 minutes) when it seemed like there was a loss of power and eventually the tractor stopped and I had the same thing I had experienced earlier. I couldn"t go forward, or rather I would go forward in a jump and start (like a 16 year old driver trying to work a clutch on a car - a bit of a jump,stop,stall). It also seemed at one point that one tire was trying to turn while the other was fixed -- which caused the tractor to lurch to the left. For what it is worth it was now about 8 degrees temp with a wicked wind. When I shut the tractor off for a few minutes and then started it up again I was able to go forward normally for about 50 yards, and then the same thing happened. I let it sit for a few minutes and then was able to get it back to the shed about 150 yards away relatively normally ... though it seemed like there wasn"t a lot of power. There are a few other (maybe not random) things I noticed. One, the brakes suddenly seem to be not working great. Everything else seems normal. Hydraulics worked fine. It wasn"t hard to get the stick shift into gear. I had the rear tires changed (by a shop) before this happened. One rim had rusted through and had to be replaced. I ran the tractor once briefly before it stopped starting this fall, so I don"t know if there was any relationship between tire changing and this most recent problem (seems really weird to me that there would be). I am befuddled. Any ideas? Thanks ep |
| leeedwin9
01-20-2013 22:54:29
208.103.28.73
Re: Puzzling problem - IH 284 -- intermitant stuck transmissi... in reply to escottpeterson, 01-19-2013 17:02:09
| | ES--Check the cover on your 284 brake reservoir, the covers are made of plastic and they develop cracks over time. If rain water gains entrance to the brake fluid area it can lead to frozen brakes. --Lee |
| G Conn
01-20-2013 14:26:26
74.218.217.94
| I have a 284 , have you checked the parking brake??? maybe not a problem but not mention ?? |
| Allan In NE
01-20-2013 05:26:23
148.66.88.254
| | Ice in the tranny/rear end? Allan |
| escottpeterson
01-20-2013 08:09:31
67.7.198.128
Re: Puzzling problem - IH 284 -- intermitant stuck transmissi... in reply to Allan In NE, 01-20-2013 05:26:23
| Thanks for the reply. No ice -- drained it and tho it looked a tad dirty, nowhere near ice or sludge. |
| mkirsch
01-19-2013 17:16:21
67.253.161.186
Re: Puzzling problem - IH 284 -- intermitant stuck transmiss in reply to escottpeterson, 01-19-2013 17:02:09
| Could be a siezed bearing or the brake hanging up. When it won't move will it roll with the transmission in neutral?
Jack it up and try turning the rear wheels. IF one turns harder than the other you've at least isolated the problem.
I doubt if ice is your problem. The hydraulics would warm up the fluid and melt any ice in there. |
| escottpeterson
01-20-2013 08:23:23
67.7.198.128
Re: Puzzling problem - IH 284 -- intermitant stuck transmiss in reply to mkirsch, 01-19-2013 17:16:21
| | mkirsch and janicholson. A bit of an update, and thanks for hanging in there with me. I put it in neutral this morning and tried to push, but alas at 165 pounds I am little match for a ton tractor to make a real test of it in the shed. So I started it up and backed it up a bit (no problems at all) and then let it roll forward in neutral about 5 feet. That worked. I jacked the back end up and when in neutral I couldn"t turn either wheel. Not sure if I was doing something wrong or not, but it also seems like a lot of gears to turn by hand so can"t answer whether on wheel turns harder than another ???? But here is something new I discovered as I looked at the brake mechanism. First off, the seals all look good around the linkages. But when I push the brake down there is no give (and when moving forward little braking action)-- push pedal ... no movement of anything to actually "brake". But when I decouple the brake pedal (there is a bar that connects the right and left pedals so they go down together) the left pedal - presumably for the left rear wheel brake appears to work normally (push the pedal and it moves -- tho what "normal" means is a guess since I have never looked at it before) while the right pedal - presumably for the right rear wheel won"t budge. It makes me think that if a brake is stuck it might be that one. Make sense? Now -- how does one "unstick" a brake? And why if the brake is stuck on can I back up or move in a normal manner at all? Thanks for your brains on this one. |
| Janicholson
01-20-2013 08:57:51
74.60.94.18
Re: Puzzling problem - IH 284 -- intermitant stuck transmiss in reply to escottpeterson, 01-20-2013 08:23:23
| The brakes are hydraulic (as shown in the caseih.com on line parts description) As such they should move at the pedal about an inch before doing any braking. If one pedal is rigid, and does not move, it could be that the brake cylinder is mis adjusted and not allowing the pressure to be released. The piston in the master cylinder for that brake must retract all the way to the limit of the bore. if it doesn"t. or if the cup is swelled up covering the compensating port, the brake will stay on. If both wheels are in the air, and the engine is off and the trans is in any gear, one tire should spin forward moving the other backward (differential) easily. If not, there is an issue with either brakes (I hope because it is easy) or a bearing, Jim |
| escottpeterson
02-02-2013 12:43:43
67.7.211.219
Re: Puzzling problem - IH 284 -- intermitant stuck transmiss in reply to Janicholson, 01-20-2013 08:57:51
| | Was out of town so couldn't work on the tractor for a while. Weather hasn't warmed up (-25 this morning) but today I jacked up the back end and the back wheels turn pretty easily, except at one point they get significantly tougher to turn. The resistance lasts about 1/4 or less of a turn, then gets easier again. No noticeable difference between tires turning. The seals on the brake cylinders are intact, although as I said earlier when I disengage the bar that connects the two brake pedals the left pedal has play and the right one doesn't move at all. Does this help at all with the diagnosis? If the brake cylinder was frozen would the wheels turn? Thanks. Erik |
| Escottpeterson
01-20-2013 12:36:05
198.228.228.175
| Thanks Jim. Out of town for a few days but will try when I get back with what I find. Thanks for your help. Erik |
| escottpeterson
01-19-2013 17:43:04
67.7.220.134
| | thanks for the prompt reply. I will check that out tomorrow morning. It felt like it wouldn't roll in neutral, but I didn't put a real shoulder into it either. Why would it appear to work fine with the fresh hy-tran fluid for a brief time, and then seize up again if it were a hung up brake or seized bearing? Could those be intermittent? I will post what I find out. |
| Janicholson
01-19-2013 19:16:46
74.60.94.18
Re: Puzzling problem - IH 284 -- intermitant stuck transmiss in reply to escottpeterson, 01-19-2013 17:43:04
| I agree with mkirsch, Bearings going out (particularly roller but ball bearings as well will act that way. Sevier damage can result to the housings or case if allowed to be operated as is. Jim |
| Escottpeterson
01-20-2013 06:46:37
198.228.228.171
Re: Puzzling problem - IH 284 -- intermitant stuck transmiss in reply to Janicholson, 01-19-2013 19:16:46
| | This is very helpful in narrowing it down. Going out to check what I can find (unfortunately the temp dropped to -15 so it"ll be a bit chillier. Question about the bearings if it is a bearing. Best thoughts on which one?: The mainshaft bearing, differential bearings or in the wheel assembly/hub itself? Probably any of those is outside my league since I don"t have the equipment to lift or pull that large. Thanks again for all the help. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
