TractorLinks.com
Show Parts for Model:
Re: Farmall M distributor
Janicholson
01-19-2013 13:01:23
I agree with old, it is also possible to use a slightly longer bushing that contacts unworn shaft. Bushings are available and or can be made easily. Shaft clearance should be at or less than .001" Jim
The tractor vet
01-19-2013 16:21:59
 Re: Farmall M distributor in reply to Janicholson, 01-19-2013 13:01:23
Just went thru this on the one 706 , NO BUSHINGS from Case I H , no new shaft either . And i have been unsuccessful in finding a used dist for the C291 . So we had a machinest turn down and polish up the old shaft and make new bushings up even cut the drain back slot in the bottom bushing worked well for three hours then she seized up on the top bushing and locked up and took the brand new oil pump and twisted the shaft off. SOOooooooo that one is setting till warmer weather . Not sure just what i am going to do yet .
