Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Cluch slipping on friends H Puller
01-19-2013 08:51:21
When an engine is powerful enough to slip the clutch, and the clutch is new (my take on your statement above) a heavier duty clutch cover is needed. Sometimes a puck style driven disk will grab better and work with standard Pressure plate.
Rebuilding the clutch Pressure plate with different primary springs is another option. If you try the rebuild option, stock springs can be shimmed to provide that additional force if (and only if) the coils are not forced together into coil bind when the pedal is fully depressed. Valve spring shims of the correct diameter will work. Jim
