TractorLinks.com
Show Parts for Model:
Cluch slipping on friends H Puller
Too Far Gone
01-19-2013 02:33:32
He's asking me to see if it can be sdjusted,but its been a long time since I adjusted on a pressure plate.I remember you loosen the jam nuts and turn the bolts equal amounts,BUT which way do they turn(in or out ) for more pressure,I know its new and hasnt slipped on him til now.Thanks for any response
Owen Aaland
01-20-2013 23:09:44
 Re: Cluch slipping on friends H Puller in reply to Too Far Gone, 01-19-2013 02:33:32
You only need to use the three bolts if you replace the clutch without splitting the tractor.
Hoof print
01-20-2013 04:23:43
Your friend did remove the bolts holding the pressure plate together after installation didn't he?
I bought an h with a slipping clutch once, did not take me long to find the problem! The knucklehead left the bolts in.
This post was edited by hoof print at 08:37:18 01/20/13.
Too Far Gone
01-20-2013 10:03:29
 Re: Cluch slipping on friends H Puller in reply to Hoof print, 01-20-2013 04:23:43
Beats me,I wasnt there.I never use thos bolts.Ive always had good luck givin it a little wiggle and things fall together
Pete in Holland, MI
01-19-2013 19:47:04
Machines, like tractors, are designed to operate as a unit, with all parts specified to work as a team.
When you build up the engine to create more horse power, the designers did not take that into consideration.
Hot-rodding a tractor or car, experts say you have to start from the rear of the vehicle and improve as you work forward. If you start from the front, you will have disappointments.
Too Far Gone
01-19-2013 21:08:08
 Re: Cluch slipping on friends H Puller in reply to Pete in Holland, MI, 01-19-2013 19:47:04
Who mentioned a hot rod dude?Its just a good stock tractor with super h kit
The tractor vet
01-19-2013 16:25:36
When i still had the shop open i had Hy Capacity build me three pulling clutches for Farmall H's . Yep they DID NOT SLIP and ya had best build up your left leg to hold them down for any length of time .
Too Far Gone
01-19-2013 21:09:11
 Re: Cluch slipping on friends H Puller in reply to The tractor vet, 01-19-2013 16:25:36
Yeah,It seems like they'll never wave the green sometimes
Janicholson
01-19-2013 08:51:21
When an engine is powerful enough to slip the clutch, and the clutch is new (my take on your statement above) a heavier duty clutch cover is needed. Sometimes a puck style driven disk will grab better and work with standard Pressure plate.
Rebuilding the clutch Pressure plate with different primary springs is another option. If you try the rebuild option, stock springs can be shimmed to provide that additional force if (and only if) the coils are not forced together into coil bind when the pedal is fully depressed. Valve spring shims of the correct diameter will work. Jim
wayne in mn
01-19-2013 06:17:30
The adjusting screws do not change spring pressure; they set the throwout bearing position.
Time to replace parts & resurface the flywheel.
K-Mo
01-19-2013 06:03:52
If free pedal is good then there's not much you can do.
If the clutch is new, was the flywheel resurfaced.
With a new clutch disc, pressure plate and resurfaced flywheel, there should be no problem.
Too Far Gone
01-19-2013 08:21:04
 Re: Cluch slipping on friends H Puller in reply to K-Mo, 01-19-2013 06:03:52
Kinda what I originally thought.I usually have always just replaced the clutch and been fine.I think he just has wishful thinking.
Zachary Hoyt
01-19-2013 05:04:03
Have you checked the pedal free play? That is often the place to start with a clutch problem.
Zach
Too Far Gone
01-19-2013 09:04:47
 Re: Cluch slipping on friends H Puller in reply to Zachary Hoyt, 01-19-2013 05:04:03
He just told me theres way too much of free play
Janicholson
01-19-2013 10:31:09
 Re: Cluch slipping on friends H Puller in reply to Too Far Gone, 01-19-2013 09:04:47
THe only way freeplay can make slippage is if it dos not exist, as in there is no freeplay. Too much still lets the clutch engage (pinch the driven disk) as much as it can. Which is not enough evidently. As the driven disk wears, it gets thinner, reducing freeplay, not increasing it. So the issue is still going to be including a split of the tractor. Jim
Too Far Gone
01-19-2013 19:26:16
 Re: Cluch slipping on friends H Puller in reply to Janicholson, 01-19-2013 10:31:09
Yeah,I told him to split it and order a 10.5 inch clutch and heavier pressure plate I found for pulling on a website
