| Author |
[Modern View]
| Ethan Chamberlain
01-18-2013 05:08:18
64.89.219.217
Hello I'm looking at a 1566, and was about ready to buy it until we tried to start it and nothing at all happened. We cracked fuel lines at the head, and have fuel there. We can get it to turn over with the starter by jumping the terminals with a screwdriver, but it won't fire or even smoke. We even tried helping it with some ether, but it still didn't fire. I had new battery's in it, so it shouldn't be a cranking speed problem. I'm out of ideas. What do you guys think? |
| Pat-CT
01-20-2013 16:13:56
68.9.213.240
Re: 1566 ih in reply to Ethan Chamberlain, 01-18-2013 05:08:18
| This time of year it could have had the fuel gel, should have done something off the juice though, although I have seen tractors not do anything off ether before to.... If your having fuel at the injectors then I would make sure air is completely bled out of the pump.... give it some ether and bring it to WOT. |
| scotc
01-18-2013 20:43:57
75.234.211.73
| | Did you have the throttle wide open? How did the air filter look? |
| Ethan Chamberlain
01-19-2013 06:48:45
64.89.219.217
Re: 1566 ih in reply to scotc, 01-18-2013 20:43:57
| When I pulled the air cleaner out it was plugged off with silt. Even when I pulled both air cleaners out it still would not do anything. I had the throttle about half open. |
| scotc
01-20-2013 15:33:44
75.238.252.251
Re: 1566 ih in reply to Ethan Chamberlain, 01-19-2013 06:48:45
| | The pump advances when you open the throttle, they start way better full open. I learned that JD's are the opposite, they advance til it gets oil pressure, and giving it any throttle you lose the advance and they start like crp. But it should have fired off with the ether, if you shot it in with the air filters out. If there was dirt in the housing around the air filters, it could be the engine is damaged. You are getting good flow out of the fuel tank? |
| Ethan Chamberlain
01-18-2013 07:32:29
174.255.144.155
| Her price was 3000. How does that sound? |
| kennell
01-19-2013 06:05:59
142.68.124.175
Re: 1566 ih in reply to Ethan Chamberlain, 01-18-2013 07:32:29
| I'd buy it in a flash if the tires hold air and the tractirs complete. Kent |
| DeltaRed
01-18-2013 07:57:22
71.208.8.212
| If no smoke,the throttle is in the 'stop' position;the thing was run out of fuel;the fuel system has lost prime(could be bad) ;the pump is shot(worse);The fuel filters are plugged,or frozen.Block of ice in the tank plugging the suction.These things are something to look at..... |
| dhermesc
01-18-2013 11:38:15
24.248.193.103
Re: 1566 ih in reply to DeltaRed, 01-18-2013 07:57:22
| I would agree but it still should have fired/smoked a bit with the ether. |
| John A.
01-18-2013 06:22:15
64.128.16.238
| Ethan, Always look for the obvious first, know it sounds dumb, but make sure the throttle is correctly set so it is not in the Kill position. could be that is is hung up there. If you are spinning the engine smartly, throttle is not in the Kill position and not getting some smoke there are probable Injection pump problems. Have the man adjust the price accordingly, or walk away. Hope this helps Later, John A. |
| mkirsch
01-18-2013 06:13:50
64.80.110.74
| It should've fired easily at 34 degrees.
Those IH 400-series engines are good cold starters if everything is working even close to right.
The 1066 only ever got started during the winter to run the generator or go on "rescue missions" when the spreader tractor got stuck. That tractor would always fire up even down into single-digit temperatures, with nothing more than a quick puff of ether, if that.
Unless you can get the tractor for scrap price plus the value of the tires if they're any good, walk away. |
| dhermesc
01-18-2013 05:45:40
24.248.193.103
| How cold was it where you were starting it? |
| Ethan Chamberlain
01-18-2013 06:02:28
64.89.219.217
Re: 1566 ih in reply to dhermesc, 01-18-2013 05:45:40
| It was somewhere around the 34 degree mark. |
| El Toro
01-18-2013 05:36:29
108.3.143.30
| Ethan Chamberlain
01-18-2013 05:10:34
64.89.219.217
| I can turn the key and get power to the gauges, but the pushbutton is gone, so that is why I have to jump terminals with a screwdriver. |
| MN Scott
01-18-2013 07:45:51
69.179.20.36
Re: 1566 ih in reply to Ethan Chamberlain, 01-18-2013 05:10:34
| Don't know how familiar you are with IH tractors but the 66 series tractors have a safety switch on the clutch. You have to have the clutch fully depressed for the starter to engage. |
