Farmall C generator
Is there a way to test the generator on a farmall c by disconnecting all the wiring. I have a c I rebuilt and I had the generator redone but I can not get it to charge I have done everything I hav polarized it. There is one of two things wrong I have something wired wrong although I have been back through the wiring or the genrator just is not working. I have messed with this thing for about two months any help would be appreciated. The tractor starts and runs goo just can't charge the battery. It is 6 volt
Do a motor test as in hook up a ground to the frame and in this case + ground and then hook the other side to the posts on the generator. If it is good it should motor as in work like a motor.
