TractorLinks.com
Show Parts for Model:
Re: Farmall SMTA Valve chatter issue
rustred
01-16-2013 11:24:59
yes, and remove coil so can get at bolt behind.
Brady Miller
01-16-2013 12:50:46
 Re: Farmall SMTA Valve chatter issue in reply to rustred, 01-16-2013 11:24:59
Are we removing just the distrbutor or the distributor and the live hydraulic pump?
rustred
01-16-2013 13:02:36
 Re: Farmall SMTA Valve chatter issue in reply to Brady Miller, 01-16-2013 12:50:46
JUST distributer, the 2 5/16 bolts that takes a 1/2" wrench. that have a special clamp to allow the turning of dist. that is the only way you will get dist in proper position.you need to remove coil to get at inside bolt. absolutly no reason to remove pump or housing in front of pump.
