| Farmall & IHC Tractors Discussion Forum |
Topic: Re: Farmall SMTA Valve chatter issue
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| rustred
01-16-2013 08:47:06
209.115.232.65
ok, now thats what i thought. that terminal with the wires needs to be at 3 oclock, which requires pulling the dist out and getting it in proper order.same with the plug wires there not correct either. now next step. |
| rustred
01-16-2013 08:57:07
209.115.232.65
Re: Farmall SMTA Valve chatter issue in reply to rustred, 01-16-2013 08:47:06
| now get #1 cyl. on compression at tdc. take out the 2 dist bolts with clamps and pull out dist. have cap off, turn rotor to 2 oclock as viewed from behind. hold dist so wire terminal is at 3 oclock and reinstall dist. leave bolts slightly loose. recheck your timing marks on front pully make sure correct. turn on ignition and rotate dist clockwise a bit, then turn counter clockwise till you just hear the spark snap. that is where you tighten the dist and you are timed.thats it. good luck |
| Brady Miller
01-16-2013 09:19:52
65.255.71.108
Re: Farmall SMTA Valve chatter issue in reply to rustred, 01-16-2013 08:57:07
| Remove the 2 bolts below the where the coil is bolted correct? |
| rustred
01-16-2013 11:24:59
209.115.232.65
Re: Farmall SMTA Valve chatter issue in reply to Brady Miller, 01-16-2013 09:19:52
| yes, and remove coil so can get at bolt behind. |
| Brady Miller
01-16-2013 12:50:46
172.0.215.29
Re: Farmall SMTA Valve chatter issue in reply to rustred, 01-16-2013 11:24:59
| Are we removing just the distrbutor or the distributor and the live hydraulic pump? |
| rustred
01-16-2013 13:02:36
209.115.232.65
Re: Farmall SMTA Valve chatter issue in reply to Brady Miller, 01-16-2013 12:50:46
| JUST distributer, the 2 5/16 bolts that takes a 1/2" wrench. that have a special clamp to allow the turning of dist. that is the only way you will get dist in proper position.you need to remove coil to get at inside bolt. absolutly no reason to remove pump or housing in front of pump. |
| Brady Miller
01-16-2013 08:55:11
65.255.71.108
| So, that terminal is the cap that the plug wires plug into? or is it the single wire coming from the coil? |
| rustred
01-16-2013 09:00:56
209.115.232.65
Re: Farmall SMTA Valve chatter issue in reply to Brady Miller, 01-16-2013 08:55:11
| the terminal that is jammed into the coil and preventing rotation. it has to be at 3 oclock not 12 oclock as pictured. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
