TractorLinks.com
Show Parts for Model:
Re: Farmall SMTA Valve chatter issue
rustred
01-16-2013 08:12:22
the wire terminal on dist. is to be positioned at 3 oclock position from factory.and #1spark plug wire is at 2 oclock position. this gives all kind of retard and advance travel when you loosen the two dist hold down bolts and turn accordingly.
Brady Miller
01-16-2013 08:20:28
 Re: Farmall SMTA Valve chatter issue in reply to rustred, 01-16-2013 08:12:22
So are you talking about turning the cap to retard? or Finding top dead center of number 1, then remove that rotor cap in distributor to 2 o"clock while the spark plug cap on distributor is at 3 o clock right?
rustred
01-16-2013 08:39:59
 Re: Farmall SMTA Valve chatter issue in reply to Brady Miller, 01-16-2013 08:20:28
no, i am saying that #1 spark plug goes to 2 oclock position on dist cap... thats a factory position. the little screw for the points on the distributer goes to the 3 oclock position... from factory. i am saying this cause i dont know what how your dist. is positioned and you say you have no travel. or just post a pic. of dist on tractor. you have to have dist. in proper position to get proper travel. once this is found out will go to next step.
