TractorLinks.com
Show Parts for Model:
Re: SM brake/clutch petal shaft seals
D Slater
01-16-2013 05:10:29
Should be the right number. Have recieved parts packaged wrong a time or two from them. NAPA cross over number seal is listed as 1.125 ID and 1.832 OD. Should have some other seal numbers when I make it out to the shop. Up to you on the number of seals, one is all I use there. National seal # 470045. SK or CR 11171. I prefer the national over the other.
This post was edited by D Slater at 06:27:46 01/16/13.
47 Bill
01-17-2013 03:18:12
 Re: SM brake/clutch petal shaft seals in reply to D Slater, 01-16-2013 05:10:29
Thanks for the info. My mistake was that I had not removed the old seal first, as I like to make sure I have the right ones before starting. I had measured the 2 1/8 bore where the washer seats. After removing 60 years of crud, I see the stepped down bore for the seal.
