SM brake/clutch petal shaft seals
Anonymous-0
Looking for seals for 52 Super M brake/clutch pedal shaft. Case IH sent 380959R91 seals, too small. Case says that is the only part number they have. Shaft is 1&1/8 dia, seal seat is 2 &1/8 dia. Anyone have a good part no? Do I need to use two seals per side,as originals look much wider than new ones.
Go to a local auto parts store, if the parts guys there are any good they can get the right seal by going off the dimensions if nothing else. One seal per side is sufficient.
Should be the right number. Have recieved parts packaged wrong a time or two from them. NAPA cross over number seal is listed as 1.125 ID and 1.832 OD. Should have some other seal numbers when I make it out to the shop. Up to you on the number of seals, one is all I use there.
National seal # 470045. SK or CR 11171. I prefer the national over the other.
Thanks for the info. My mistake was that I had not removed the old seal first, as I like to make sure I have the right ones before starting. I had measured the 2 1/8 bore where the washer seats. After removing 60 years of crud, I see the stepped down bore for the seal.
