Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: H4 magneto Checked and gone through, no fire
Daniel Dillon
01-13-2013 11:30:27
Well in response to both, the points are new but I will rub the contacts, timing has not been changed or touched, I am very careful to be sure everything is aligned just as it was when I first pulled the mag, But even if timing was out should I not get a spark indication directly from the secondary side of coil. I am confused as continuity is good with no grounding to anything, except points show continuity to ground when my coil is hooked up, but I read this is normal since resistance is so low on the primary side. If points and condenser are new and have been replaced, what could possible change by just sitting for 4 years.
01-13-2013 13:35:59
 Re: H4 magneto Checked and gone through, no fire in reply to Daniel Dillon, 01-13-2013 11:30:27
The points do neeed polishing, they are often covered with factory corrosion inhibitor. If the rotor shaft is in time with the cam, it should operate. Jim
Daniel Dillon
01-13-2013 20:42:58
 Re: H4 magneto Checked and gone through, no fire in reply to Janicholson, 01-13-2013 13:35:59
Yeah I hope this takes care of it, need my H running, getting old to do some of grunting around the yard by hand :^) I know I shouldn't have let it sit as long as I did but getting back to it now has only rekindled my tractor interest and got me to thinking about the one I have never owned and always wanted, maybe one of these days I will park a Farmall 560 diesel next to my H
