Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Hard starting M
[Return to Forum]
Animal
01-12-2013 14:44:13
76.0.45.68
When this tractor is cold its a bear to start. I have to use my hand to choke it, regular choking does not get it done. After it starts and warms a little it starts well. No intake leaks fuel and fire are real good. I am leaning toward a tight valve or two. I have never been around a farmall that started this hard..
[Reply]   [No Email]
David G
01-13-2013 08:31:25
205.215.206.18
Re: Hard starting M in reply to Animal, 01-12-2013 14:44:13
I would think it is a lean mixture, the valves will get tighter as the push rods warm up and expand.
  [Reply]  [No Email]
pete 23
01-12-2013 16:53:58
74.32.229.189
If it happens to have that spring loaded , unloading valve in the choke plate, I solder them shut. That thing will let enough air in to not choke properly with a cold slow turning engine.
  [Reply]  [No Email]
Janicholson
01-12-2013 15:26:02
74.60.94.18
If the choke plate is centered in the intake bore, it should be as ffective as your hand. A caeful look inside might show the issue. The screws have been known to unscrew. There might be a spring loaded valve in the plate as well which needs to be held against its hole. Also make sure the choke rod or cable is making full movement. Jim
  [Reply]  [No Email]
Machine249
01-12-2013 15:05:35
76.100.246.141
Not really a cure for the real problem, but you could try putting a block heater on it. Also, make sure that your engine oil and the oil in your oil bath filter is appropriate for the temp in your area. Good luck.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
