| Farmall & IHC Tractors Discussion Forum |
Topic: 450 questions
[Return to Forum]
| Author |
[Modern View]
| mike Fitz
01-12-2013 11:40:47
208.126.1.129
I have a 450 gas, that has some govenor issues,it doesn't return to idle like it should after speeding it up, I've been told it is probably just wear, that makes sense. I am wondering how hard it is to freshen up the govenor, or if parts are avaliable, or if there is any one who does this kind of work. I also would like to know if the hydraulic valve will interchange from a 350 to a 450, both were row crop,the 450 has power steering don't know about the 350. Thanks Mike |
[Reply] [No Email] | |
| mike Fitz
01-13-2013 06:40:18
208.126.1.129
Re: 450 questions in reply to mike Fitz, 01-12-2013 11:40:47
| Thanks guys, this gives me a place to start. Mike. |
| Bud Kaiser
01-12-2013 18:41:20
75.0.238.80
| I had my govenor rebuilt 3 years ago by Motec, I think his name was Matt Gall. It works like it should. |
| Bob M
01-12-2013 12:12:34
67.240.174.32
| | Before you tear into the governor, first check the the linkage is properly synchronized (adjusted) to the carb throttle shaft: Remove the cover from the governor riser (the sloped cover with a vent tube heading up to the head). Remove the cotter pin then the pivot pin from the bellcrank inside the riser. Set the governor hand lever to max speed, then pull up on both the adjusting block and the throttle shaft bellcrank as far as they will go. Now while holding the parts up, try to reinsert the pivot pin - it should slide in easily. If it does not, loosen the locknut and turn the adjusting block up or down on the threads until the pin slides in easily. The governor will now be synchronized with the carburetor. |
| pete 23
01-12-2013 11:56:26
74.32.229.189
| | Hydraulic valves are same, excluding the inner most valve on tractor with power steering and of course the flow divider valve block. Assuming factory power steering. Far as governor, all external linkages must be in good enough condition so internal high and low stop can be reached with throttle lever. Then you would have to go for internal thrust bearing and link between gov and carb condition. Worn out weights or weak spring will cause poor response to load but not affect making it idle down slow. Loose worn throttle shaft and bushing in carb also. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
