460 diesel volt regulator mounting
tntleake
Anybody got a photo of the regulator mount under the fuel tank. it's been so long since I took it apart, I can't remeber how it goes
Tracy
on the fuel filter side it goes on the back closest to you mounting bolt for the fuel tank. the long part goes down. It can be a bear to change.
He's correct on location and on a 460 they are not all that bad to mount. The 560 has a higher clutch housing so you have very little room to work under fuel tank but the 460 gives you quite a bit of space.
No spacer. The bracket the regulator mounts to has enough of a bend and drop that it clears the lip on the fuel tank support.
