heisler overdrive for m farmall
i just bought am md farmall with what i believe to be a heisler overdrive in it.it has a shift fork on the transmission countershaft between the transmission and the hydraulic pump and a shaft about an inch long on the left side of transmission above the brake and clutch pedal shaft. is this what i think it is and where do you find any information on them? thank you
Post some pics if you can... it could be a heisler or m&w 9 speed. There are a few repro manuals for the m&w from time to time on ebay. I have a m&w 9 speed for one of my mds just haven't had time to install it yet, they say that it really makes the tractor more versatile. Jim.
I have never had either one but I think I have heard that the M&W had a shaft type linkage on the right side of the tractor and the Heisler had a cable type on the left.
Zach
Not sure but think you may be looking at a hiesler 9 speed shift shaft thats missing the shift lever. Heisler also made a hydraulic pump drive disconnect.
If the pictures work, first is a hiesler. Next is a model of M&W that also had a left side shift. Last is a M&W right side lever shift lever without the M&W shift rod to the lever. Look past the hydraulic valve to the lever in front of the brake pedals. M&W also used a push pull cable shift like used for pto operation on some trucks.
thanks to all for the info. from it i have concluded that it is a heisler nine speed attachment.hope to get the tractor running in a few days and will let you all know how it works. thanks again.
