Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: D-236 in a 460
pete 23
01-10-2013 16:30:45
The good book never gave a maximum. They did at one time give new specs which were right about .032 if I remember right. I actually strived for much less when repairing with new valves and seats. Some times you can get by with flush with head but I liked to go about .010 as I did see one engine leave a very slight impression in piston with flush valves. There are different pistons though that have a slightly deeper recess so only way to know for sure is to test when fully assembled and valves adjusted. That is tricky also because the valve is not at it's closest to piston at tdc, slightly before on intake and after on exh. I have seen then down in head .080 for so and you had to light a fire in the hole to start them. Makes a tremendous difference in starting.
Fritz Maurer
01-10-2013 17:10:05
 Re: D-236 in a 460 in reply to pete 23, 01-10-2013 16:30:45
Thanks, .010" is right about where I'll be by time the head is resurfaced.
