Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: IH F400 Diesel Fuel oil pressure gauge ?
[Return to Forum]
Chuck McDonald
01-10-2013 08:39:16
66.243.220.1
I am replacing the fuel pressure gauge on my F400 injection pump. Here is a pic of the remains of the fitting that the original gauge was screwed into. Part of it did break off in the fuel line housing at the time of removal. Is this type critical, or would a regular brass fitting work for this application?
Thanks
Chuck
[Reply]   [No Email]
pete 23
01-10-2013 16:40:58
74.32.229.189
 Re: IH F400 Diesel Fuel oil pressure gauge ? in reply to Chuck McDonald, 01-10-2013 08:39:16
Just put in a new gauge with out adaptor. If it
reads steady you are in bussiness. If it jumps all
over the place, get a hold of a brass fitting,
solder end full of solder, drill a small orfice and
try that. Some applications use two orfices in
series to dampen pressure spikes. That is what they
do in the compensator on the closed center
hydraulics used in the 86 series tractors.
[Reply]  [No Email]
Phil Tibbetts
01-10-2013 15:17:05
208.93.14.38
There may have been a small orifice hole in that piece to prevent shock to the gauge. Just a possibility, not uncommon.
[Reply]  [No Email]
rustred
01-10-2013 16:16:57
209.115.232.65
 Re: IH F400 Diesel Fuel oil pressure gauge ? in reply to Phil Tibbetts, 01-10-2013 15:17:05
the guage has the orfice hole.
[Reply]  [No Email]
rustred
01-10-2013 11:02:05
209.115.232.65
you took it off at the wrong place. that brass fitting stays in pump and does not go with guage. i am not sure on the brass fitting , as never removed one to know whats behind it.can you remove the housing to remove the broken piece if it is indeed broken as i think just screw that one back in and try it to see if you get pressure on the guage.
[Reply]  [No Email]
Chuck McDonald
01-10-2013 14:17:23
66.243.220.1
 Re: IH F400 Diesel Fuel oil pressure gauge ? in reply to rustred, 01-10-2013 11:02:05
It might not be visible in the pics, but the threads sheared half off and came out in pieces. It was leaking and I attempted to tighten it.....bad idea. Looked to me like it had be cracked and I finished it off.
So do I have to have that?
Chuck
[Reply]  [No Email]
rustred
01-10-2013 14:26:54
209.115.232.65
 Re: IH F400 Diesel Fuel oil pressure gauge ? in reply to Chuck McDonald, 01-10-2013 14:17:23
i see. i kind of think dont need the exact fitting. should be able to put a 1/4 npt hyd. fitting like that but just make sure the male part of brass fitting is indeed 1/4 npt. after studying that brass fitting i think that is just a built in valve so that when the guage is removed it dont drain the system and allow air in. my thoughts though.
[Reply]  [No Email]
Chuck McDonald
01-10-2013 14:19:57
66.243.220.1
Might attempt to clean up the remaining threads, put a very small amount of thread tape on it and try to put it back on the pump.
Chuck
[Reply]  [No Email]
Chuck McDonald
01-10-2013 14:21:20
66.243.220.1
 Re: IH F400 Diesel Fuel oil pressure gauge ? in reply to Chuck McDonald, 01-10-2013 14:19:57
FYI, I know that it didn't have to be removed, but it came off in my hand that way.........Would have preferred to just replace the gauge......
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
