Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: IH 674 D239 Engine replacement
rustred
01-10-2013 08:06:07
well if you say it has ben run with diesel in the oil then thats a very good reson for the blowby. the diesel glazes the cyl. walls and the tractor will use a lot of oil. the most likely cause would be the injection pump shaft seal leaking diesel into oil pan. pull the head off first and check things out. may only need a set of rings and deglaze cyl's. best is to check this engine out first before getting involved with another one. you may get away a lot cheaper.
rustred
01-10-2013 08:18:09
 Re: IH 674 D239 Engine replacement in reply to rustred, 01-10-2013 08:06:07
yes, definitly do as allan says, before tearing down. i had a tractor with diesel in oil and also worked the heck out of it but it would not smarten up so i had to tear it down. but thats a last option. all it took was a set of rings and deglazing.
