TractorLinks.com
Show Parts for Model:
Re: wiring question
marc walker
01-09-2013 16:31:36
I have been running the tractor off and on for the past week with no on/off problems, it started acting up when I changed the altenator today. Marc
Janicholson
01-09-2013 17:26:52
 Re: wiring question in reply to marc walker, 01-09-2013 16:31:36
does it have the diode or lamp, or resistor in the #1 terminal connection? If the original Alternator was a One Wire design, it might work with that terminal connected and not fail. but a real 3 wire must have it, no exceptions. Jim
marc walker
01-09-2013 17:34:06
 Re: wiring question in reply to Janicholson, 01-09-2013 17:26:52
Jim, it has none of the above in line, I can disconect the jumper from the #2 side wire to large battery terminal and the on/off switch works. So I will add a diode tomorrow, will that be sufficent? .Thanks for the help.
old
01-09-2013 18:05:52
 Re: wiring question in reply to marc walker, 01-09-2013 17:34:06
Radio shack part #276-1661 works great and cost around $2.50 for a pack of 4 and it over kill so you never have to worry about burning it out. The silver line goes to the alternator side in the #1 wire off the 2 wire plug
Janicholson
01-09-2013 17:54:58
The diode goes in the wire from #1 to the ignition, with the band on the diode toward the alternator #1 spade terminal. The #2 terminal should be connected to the Big output terminal going to the amp meter. (short lead) it needs to be able to handle about 3 amps. (an old alternator can be scavenged to take apart the diode bridge removing one of the 6 diodes. (these are often not marked for polarity, so test it to assure it cannot pass electricity from the alt to the ign. but will from ign. to alt. Jim
marc walker
01-09-2013 18:40:43
 Re: wiring question in reply to Janicholson, 01-09-2013 17:54:58
I'll get her done tomorrow, Thanks for your time. Marc
