Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
M starter button
Animal
01-09-2013 15:26:32
Do any of you happen to have a parts number from a decent auto parts house for an M starter button, I do not want any more foreign junk if I can help it....Thanks Animal
mkirsch
01-10-2013 12:51:01
 Re: M starter button in reply to Animal, 01-09-2013 15:26:32
There was no such thing as a Chinese switch 35 years ago. That's when Dad put a solenoid on the M because he was sick of the push button switches not holding up.
You can't push the switch fast enough to keep it from arcing and burning the contacts over time. That's why they don't hold up.
MisterT
01-10-2013 14:31:28
 Re: M starter button in reply to mkirsch, 01-10-2013 12:51:01
A solenoid has the very same type of electrical contacts inside of it that the push button starter switch has. Used to be those solenoids could be dis-assembled, the contacts rotated to a previously un-used position, and the solenoid would be just like a new one.
Bill in IL
01-10-2013 08:16:46
They don't last long that's for sure no matter where you buy them.
I used the original start switch to energize a 6 volt solenoid that I hid behind the battery box. Solved all my buring up switches problems.
I have since converted that tractor to 12 volt and reduced my starting problems even more.
David G
01-09-2013 19:32:01
Tractor Supply carries them.
old
01-09-2013 18:02:39
I do not have that number but all I have to do is make a call and I can have it.
Janicholson
01-09-2013 17:21:02
This could be it! Jim
MisterT
01-09-2013 16:49:43
 Re: M starter button in reply to Den N Ms, 01-09-2013 15:26:32
Any of the auto parts houses will have the same button, made in the same place. The exception MIGHT be a Case-IH dealer, but don't bet on that.
